oil pressure problems
Old Feb 23, 2011 | 03:21 PM
gettough44's Avatar
gettough44 is on a distinguished road
Default oil pressure problems
ok i have a 99 blazer zr2. when first starting truck its at about 40. when it warms up drops to about 20 and makes a clanking noise that comes and goes. im not exactly sure whats wrong with it. and pressure is fine while driving. so im replacing the main bearings changing oil and filter and cleaning oil pan screen. tell me what you think.
Old Feb 23, 2011 | 05:40 PM
blazinloud's Avatar
I think your throwing parts at it hoping to fix an unknown problem. what oil and filter are you using? its not uncommon for the valves to make noise, you need to isolate as best you can where the sound is coming from.
40+ cold and 20 hot is perfectly normal.
Old Feb 23, 2011 | 06:26 PM
gettough44's Avatar
sounds like its coming from bottom end. i was thinking it might be bearings but at same time i think it might just be gunked up and screen blocked.
LWegner
May 8, 2011 08:25 AM
Spectreblazer
Mar 15, 2010 11:16 PM
davidsv8mustang
Feb 18, 2010 02:29 PM
zippy199
Oct 22, 2009 06:36 PM
Ak95Blazer
Jan 7, 2009 06:56 AM
