oil pump
Old May 8, 2013 | 07:38 PM
Kaser1026's Avatar
Kaser1026 is on a distinguished road
Default oil pump
I have a 91 s10 blazer and need to replace oil pump. Is the oil pan the only thing i need to remove
Old May 8, 2013 | 07:47 PM
richphotos's Avatar
Depends, is it 4wd?
Old May 8, 2013 | 07:51 PM
Kaser1026's Avatar
Sorry yes 4wd
Old May 8, 2013 | 08:25 PM
chris015's Avatar
What makes you believe the pumps bad? remember,oil pumps do not provide pressure. It just pumps oil and the tolerances of bearings etc creates the pressure. Worn out bearings etc will cause a low oil pressure problem.
Old May 8, 2013 | 08:59 PM
Kaser1026's Avatar
Ok i had a fluttering gauge replaced sending unit fixed that. Now oil pressure drops to 0 after driven about 20 miles cold and about 10 miles warm. I just figured a 30 dollar oil pump would be worth a shot before pulling engine out. Agree?
Old May 8, 2013 | 09:00 PM
Kaser1026's Avatar
Shut it off and turn back on it's back to normal reading for a few miles
Old May 9, 2013 | 04:39 PM
Kaser1026's Avatar
So can anyone tell me what all needs removed. And also is the oil pump a possibility?
Old May 9, 2013 | 05:54 PM
chris015's Avatar
yeaaa maybe. but chances are motor is due a rebuild. let us know how it goes.
Old May 9, 2013 | 06:07 PM
Kaser1026's Avatar
Will do. Just have to figure out what all needs to come off lol. Engine only has 106000 miles so hope it is just oil pump was hoping to wait till we move to pull engine out
Old May 9, 2013 | 07:17 PM
richphotos's Avatar
to remove the oil pump in a 4wd you have to remove the engine anyways.
