Oil pump replacement
So I've completely removed my entire front suspension on my 2000 4x4 blazer for a rebuild. I'm debating putting a new oil pump in the motor while I have access. I have the typical low oil presser issue. I've never done this on a motor still in a car. how do I make sure that the rod for the oil pump and distributor go in correctly? I think I am overthinking the whole process. Anyone ever done it this way? Any pointers?
Hello Mason,
I see nobody has given you any thoughts on this but I will say this, it really makes no difference to the pump if the shaft is in this way or that. It can not be 180 deg out as the distributor can, as long as the collar of the pump engages the bottom of the distributor shaft your golden bro..
Hello Mason,
speedzonwheels
Apr 22, 2009 10:55 AM
