oil pump... what else ?
Old Jun 16, 2012 | 12:03 AM
evomat's Avatar
evomat is on a distinguished road
Default oil pump... what else ?
replaced distributor.. went for test drive..maybe 1/4 mile . had oil pressure when i left. about 19 lbs at idle . half way thru test drive check gauges light ...no oil pressure.oh s%^t. got it home . to dark to mess with it. i am thinkin oil pump, oil pump shaft . . . not sure what else to check for . motor was running good . if i do pull oilpump what else should i repair or replace while in there? thx in advance
Old Jun 16, 2012 | 02:05 AM
red06sc's Avatar
red06sc is on a distinguished road
U sure the guage itself isnt messed up?
Old Jun 16, 2012 | 02:31 AM
NewbieT's Avatar
NewbieT is on a distinguished road
Yea you might want to get a pressure gauge before you start tearing into it. I have no idea what the spec is at idle but i'm sure a quick search would help.
Old Jun 16, 2012 | 07:33 AM
rriddle3's Avatar
At idle the minimum pressure GM specs is 8psi. Normally it will be greater than 20psi.
Old Jun 17, 2012 | 09:15 AM
evomat's Avatar
so heres my plan of attack on this . start with pulling distributor, put new oil pressure sending unit and reseating distributor. if thats not it then i guess i am doing a oil pump and shaft .
well the problem was operator error. i thought i had ditributor tightned down all the way. nope went to pull distributer and it dropped about a 1/4 ". and i noticed that i had about same left to tighten on distrbutor clamp. tightened up and ta-da oil pressure . the mechanics head was beaten against the wall several times (lol). thx to all that contributed . and hopefully this will remind others to double check what your doing and save yourself some headaches.
Last edited by rriddle3; Jun 17, 2012 at 01:23 PM. Reason: COMBINING CONSECUTIVE POSTS
jrrybrwn
27
Jan 18, 2015 08:13 PM
xG33Kx
Mar 7, 2014 06:24 PM
Jakeduece
14
Jul 27, 2013 09:33 PM
Dragon9
Oct 25, 2010 09:38 AM
YOURCONNEXX
Oct 21, 2009 07:10 PM
