Oil and Trans Temp gauges
Old Dec 24, 2008 | 12:45 AM
Doverman454's Avatar
Doverman454 is an unknown quantity at this point
Default Oil and Trans Temp gauges
So, my early christmas present came in (thank god) but, I have a problem I have no clue where to put the probe's to my 1998 S-10 blazer LS 4.3 v6 for the transmission temp and oil temp. Anyone mind giving me a bit of advice?
Thanks, Dover.
Old Dec 24, 2008 | 07:52 AM
Default RE: Oil and Trans Temp gauges
For the transmission temp, there is a port on the driver side part way up the side of the transmission. This port is typically used for pressure testing.
On the engine, you can either remove the oil pressure sending unit and put in a "T" for the temperature probe, or I believe there is a port just above the remote oil filter adapter on the rear, driver side of the engine block. This may be quite difficult to get at, but if you remove the front driveshaft, you should be able to gain access.
Old Dec 24, 2008 | 09:48 AM
Where is the oil pressure sending unit located?
Old Dec 24, 2008 | 10:22 AM
rriddle3's Avatar
IIRC it's at the top of the block, at the rear, just slightly to the driver's side of the distributor.
Old Dec 24, 2008 | 10:27 AM
Any pictures of this area? Sorry, I'm just afraid I'm going to mess something up by unbolting the wrong thing as stupid as it sounds. But I still live under my parents roof and the car is still my dads so every little thing that goes wrong is my fault. And speaking I have a brand new motor in my car it doesn't help the situation much.
Old Dec 24, 2008 | 10:35 AM
rriddle3's Avatar
Based on your statement, I'm going to highly recommend getting a Haynes or Chilton manual prior to doing the work. I always consider it a basic necessity for automotive work.
Old Dec 24, 2008 | 10:44 AM
Just asked for it as another christmas present NOW, to my next question. I bought a air/fuel ratio gauge along with that and from reading and looking it has a 4 wire oxygen sensor but my question is which wire do I tap into for the reader?
builder125
May 20, 2013 06:51 PM
tmb2003
Sep 30, 2012 08:21 PM
Fourstar200
Jan 26, 2012 02:20 PM
Mark_D
Nov 6, 2011 06:22 PM
zakm0n
Jan 9, 2011 07:31 PM
