Oil in upper intake and misfire.
Old Sep 22, 2016 | 09:24 PM
mvamobile's Avatar
mvamobile is on a distinguished road
Thanks everyone. I checked the distributor, changed the coil, and checked for arcing on the wires and everywhere else. Still no change. Could it be a sensor or maybe the cat is clogged?
Old Sep 25, 2016 | 08:21 AM
mvamobile's Avatar
I also wondered if it could have jumped time. I don't know if it would even start if that happened?
Old Oct 1, 2016 | 11:22 AM
mvamobile's Avatar
Thanks Chris015, I just changed the nut fuel lines and it was black and oily in there. I disconnected the battery while i was working on it. The battery won't hold a charge now. Now I can't get the check engine light to come back on. I let it run for over an hour,it is still running rough and no check engine light. I wonder how likely it would be the CAT clogged? If it is a clogged CAT wouldn't the check engine still come on and would it happen suddenly or gradually?
Old Oct 4, 2016 | 09:04 PM
mvamobile's Avatar
Update: I had to buy a new battery because the one i had would not hold a charge. I replaced it tonight. When i started the engine it is still jerking. I tried to put it in reverse, drive, and turned on the AC compressor. In all three instances the engine jerked even worse than before and stalled in less than 30 sec. When i would try and restart the engine it had a very long start time.
Old Oct 9, 2016 | 03:18 PM
mvamobile's Avatar
Hello everyone, I am still trying to get the codes off my Jimmy. I read in another thread on here that you can bridge pins 3 & 4 on an OBD2 connector to get the codes. I am attaching some pics of what I have. There is no pin 3. Everywhere i have taken my Jimmy, nobody's scan tool can communicate with my vehicle. Can someone help me figure this out, please?
This is the OBD plug:
https://2.bp.blogspot.com/-TZpxV8XIv...or%2BJimmy.jpg
This is the computer:
https://1.bp.blogspot.com/-NMbqHZlrb...or%2BJimmy.jpg
Old Oct 9, 2016 | 03:57 PM
AquaMan's Avatar
AquaMan is on a distinguished road
I have this little cheap scan tool.
https://www.amazon.com/Oxgord-Scanne...d2+code+reader
It works well for getting codes, but I have the same issue as you and my valve stem seals along with head gaskets have gone bad.
Old Oct 19, 2016 | 08:05 AM
smokinjoess's Avatar
smokinjoess is on a distinguished road
I wonder if a oil catch can like the ls1 and all ls motors use would be beneficial to these vortex motors.
Old Mar 10, 2021 | 06:13 PM
ElongEG's Avatar
ElongEG is on a distinguished road
Default Flashing eng light
Originally Posted by mvamobile
Thanks richphotos, The Check engine light is flashing. I have tried to get the codes but I can't find anyone with a reader that will read the codes. I forgot to put it in the list above that I have changed the EGR valve and the O2 sensor also. I did pull the EGR valve and check it the other day when I had the intake apart. As far as the brands, the only one I am sure about are the plugs. I had put Champion plugs in and I put AC Delco in last week because i kept reading on here about how bad Champions are.
check or a intake leek replace gaskets to stop the vacume leek and water from going in to your exhaust if allowed to continue the cat will clog and you will be stranded
Old Mar 10, 2021 | 06:14 PM
ElongEG's Avatar
intake is leaking will clog cat
Theblazomatic2
May 30, 2019 09:18 PM
rmh rider
Dec 6, 2010 09:43 PM
Magman
Nov 16, 2010 11:57 AM
Thor_449
Jul 24, 2008 08:05 PM
wythel
27
Jan 30, 2006 02:04 AM
