cylinder 4 and 6 have excess fuel/carbon
Old May 23, 2019 | 03:48 PM
Theblazomatic2's Avatar
Theblazomatic2 is on a distinguished road
Default cylinder 4 and 6 have excess fuel/carbon
i have a 95 blazer 4d 4wd and i recently changed plugs, wires, pickup unit, dist. rotor, dist. cap, map sensor, coil, fuel tank, fuel pump, and fuel lines .
the engine ran smooth for about 300 miles then developed a rich condition in cylinders 4 and 6. there was carbon build up on cylinder 4 plug and the spark plug from cylinder 6 was covered in fuel.it also has carbon build up in the exhaust and smells odd. it has to build itself up before it will start but it doesn't roll over hard, and has a miss when idling but at highway speeds it has no problems running and there is no power loss or acceleration problems. i cant read codes because i cant find a scanner but the light is on. is there anyone who might have had this problem and knows what could be causing it? thanks in advance.
Old May 23, 2019 | 06:32 PM
I would suggest considering the possibility that the fuel injection spider or hoses are leaking under the upper intake manifold plenum. If you take off the upper intake manifold and notice areas, especially around the #2 and #6 intake ports, that are cleaner than others, then it is likely that those are the locations where fuel has been leaking and dissolving the accumulated oil film that gets into the intake.
Old May 24, 2019 | 06:47 AM
do you think there is any other possibilities? id like to avoid taking off the intake if its possible. just looking at all the options before i start spending money. thanks for the reply
Old May 24, 2019 | 10:37 AM
I would argue that carbon build-up and the gas-soaked spark plug is pretty good evidence for leaking gas and causing an over-rich condition. Fortunately, it is not so much hard to take off the upper intake manifold but rather I would say it is more in the annoying category. Now, removing the lower intake manifold (LIM) is hard. Although, our Blazers can suffer from the LIM gaskets failing and dumping coolant into the lifter valley so it is worth considering doing. (There are lots of threads on the LIM gasket replacement.)
Try to get to an auto-parts store where they can read the codes for you. I would not be surprised if you got an O2 sensor error too. I had this happen on a 92 when my fuel injection system leaked and caused carbon buildup on the O2 sensor (in addition to the other things mentioned above.)
Furthermore, I'm pretty sure excessive gasoline leaking down the cylinder walls can dilute the oil and reducing the lubrication. If your oil smells like gas, that is another clue that you have a gas leak.
Edit: Oh and that a leak has develop suddenly is consistent with the failure mechanism being a burst connection or tubing.
Old May 27, 2019 | 07:40 AM
alright so update. i havent done anything to the vehicle except drive it. the issue is intermittent sometimes it runs normal. other times it runs like a dog. im not sure why.
Old May 30, 2019 | 06:44 PM
I think you are right here. i started checking all of the different sensors tps, iac, irv,
and distributor and others and when i pulled the intake running valve off and looked into the intake there was fuel everywhere inside the intake. so now i need to figure out what all tools i need for the job and what parts are mandatory for replacement when this service is done. any help with that info would be appreciated.
Old May 30, 2019 | 09:18 PM
Ah, you have one of the engines with the cool intake manifold. I had one in my '92. What happened on mine was that the plastic tubes between where the gas lines penetrated the back of the intake and the fuel injectors split. That was over 10 years ago so my memory is not great but I don't remember it being very hard to do, only a bit annoying to get everything off and out of the way.
daphniesman04
Jul 16, 2019 12:58 PM
silver bullet80
Nov 19, 2017 06:47 PM
DaddysBlazer
Jul 14, 2012 09:53 PM
kermit1112
20
Jan 21, 2010 11:20 AM
95jblaze
Aug 23, 2009 06:56 PM
