this one is a tough one
Old Mar 25, 2013 | 01:28 PM
  #21
Look at the bright side, when you're done fixing everything, you'll have a new truck!
Old Mar 25, 2013 | 02:46 PM
  #22
cjdavidson10's Avatar
cjdavidson10 is on a distinguished road
it will be a 1996.5
Old Mar 27, 2013 | 12:18 AM
  #23
well new tank is in new pump prime is great still leakin.. found the leak gotta wait till thursday to fix it.. will a leak in the return line keep it from starting
Old Mar 27, 2013 | 02:05 AM
  #24
newguy's Avatar
I still think its the spider, I had a leak in the return line on mine and it fired right up
Old Mar 27, 2013 | 04:20 PM
  #25
If there's a leak in the return line it should still start... unless it catches fire Gotta fix it to find out if there are any more leaks...injector assy, regulator etc.
Old Mar 27, 2013 | 11:34 PM
  #26
idk the truck is weird it will crank over and seam like it wants to catch n start but it dont
Old Mar 29, 2013 | 03:21 PM
  #27
well decided to change out the spider injectors.. as in the whole unit not a hard job got it apart got the old ones out they look in bad shape ends look cracked around end of injectors so thinking this will help alot just gotta get it all back together
Old Mar 29, 2013 | 03:51 PM
  #28
newguy's Avatar
betcha this does the trick
Old Mar 29, 2013 | 06:10 PM
  #29
well newguy ill tell yah what changed this all out and after got air out of the lines it fired up and is currently running and its about time lol 15days it was down ill take pics of the spider injectors i took off and if anyone needs to know how to change em just ask its not hard
Old Mar 29, 2013 | 06:53 PM
  #30
newguy's Avatar
been there done that
look like this
