over heating
Old Oct 17, 2013 | 02:26 PM
bdavis6247's Avatar
bdavis6247 is on a distinguished road
Default over heating
Hey everyone. First time posting. I bought a 79 K5 this past February. I live in a higher altitude then when the vehicle was in Phoenix. I jetted the carburetor and the vehicle has begun to overheat. Since then, I have replaced the water pump, changed the thermostat and it is still overheating. Is there an area I should be looking to next?
Old Oct 17, 2013 | 03:24 PM
Diaita's Avatar
Jetting too lean will make it overheat. Fan clutch?
Old Oct 17, 2013 | 03:32 PM
bdavis6247's Avatar
I'll take a look into it. My buddy has a vacuum we are gonna look into. I had it jetted at a carb shop, so I'd hope they did it the right way.
Old Oct 18, 2013 | 01:43 PM
abig84's Avatar
i second the fan clutch. mine was bad and got hot everytime i was putting around in the forest but was fine when i got moving down the road and got some air flow going through it. i bought a heavy cooling one and no more problems
Old Oct 18, 2013 | 09:08 PM
bdavis6247's Avatar
I'm going to look into the fan clutch idea. I replaced the radiator cap and it still overheated. Started to smoke where the tube connects to where the thermostat is housed at and then seemed to leak from under the engine block. Thanks for the help!
1987blazers15
Dec 23, 2009 09:45 PM
brothertonk
Dec 30, 2008 03:22 PM
jess1327
Sep 3, 2008 03:57 PM
hillbilliemedic
Aug 4, 2007 09:10 PM
Maldo15d
Jul 31, 2007 07:35 PM
