Over heating?????? help
Old Jul 1, 2007 | 02:36 PM
hillbilliemedic's Avatar
hillbilliemedic is an unknown quantity at this point
Default Over heating?????? help
94 blazer 4x4 4.3 motor.. have changed heater core, theromasate, water pump, still reads hot,, not other signs, any ideas? runs rough at times, was woundering if converter is plugged?
Old Jul 1, 2007 | 08:01 PM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
Default RE: Over heating?????? help
its prolly the temp sending unit for the gauge.
Old Jul 1, 2007 | 08:11 PM
Is it indeed running hot? Do you have a problem with coolant spilling out of the overflow bottle? If you have verified that it is not overheating, just reading high, hten it is indeed the gauge sending unit.
One often overlooked area to check is the cleanliness of the exterior of the radiator. If the cooling fins of either the radiator or A/C condenser (if applicable) are plugged up with bugs or other debris, it will run hot.
Old Aug 4, 2007 | 09:10 PM
blazerboy124's Avatar
blazerboy124 is an unknown quantity at this point
a faulty radiator cap sometimes causes the thermostat to read hot, try replacing the radiator cap.
1987blazers15
Dec 23, 2009 09:45 PM
jackburton
Apr 4, 2009 04:28 PM
brothertonk
Dec 30, 2008 03:22 PM
jess1327
Sep 3, 2008 03:57 PM
Maldo15d
Jul 31, 2007 07:35 PM
