Overheating and blowing cold air
Old Mar 31, 2022 | 08:34 PM
stickandstones's Avatar
stickandstones is on a distinguished road
Question Overheating and blowing cold air
yup, having an issue with my cooling system thermostat has been replaced. The blazer (2005, 4.3l) was running fine then recently began overheating and blowing cold air. It's been run at about 110-115 Celsius, 15 degree about operating temp. A few times 120 and presumably higher and had to turn the truck off. The thermostat is not opening until it reaches the high temps even the new one, once it does then the hot air will return. I checked for leaks which there is none, including water pump. *The coolant is in desperate need of a flush* which is on my todo list tomorrow. When the engine is at operating temp while driving; it will increase in temp at an idle so possibly water pump. I was considering the rad cap if its stuck and won't open on vacuum? Have I missed something or overlooked something? Any incite is appreciated.
*I recently bought the vehicle and it was highly neglected for maintenance prior to me owning it, today I noticed signs of the engine being rebuilt, ironically has an oil leak.
BlazaGuy95
24
Jan 26, 2014 05:58 PM
epederson
Dec 7, 2010 06:34 AM
Drivin_Foxfire
Nov 20, 2009 06:30 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
stevenson_ltdan
Jan 22, 2008 05:47 PM
