Overheating and Bubbling in the reservoir
Old Oct 31, 2009 | 09:13 AM
thechevytrucknut's Avatar
thechevytrucknut is on a distinguished road
Default Overheating and Bubbling in the reservoir
I have a 1997 4.3L 4 x 4 with 106k and it just started bubbling in the reservoir. THe Temp gauge pegs after about 5 minute of warm up. My gut reaction is to replace the thermostat... I don't have a repair manual, so I am not sure if this is my first step. Any suggestions or feedback would be greatly appreciated.
Old Oct 31, 2009 | 09:34 AM
Bubbling in the reservior would suggest that you are getting pressurized air from someplace. One source is a bad head gasket forcing air from the cylinder(s) under the compression of the piston into the cooling system. This very well could cause the quick over heating.
Are you getting any coolant out of the exhaust? Have you pulled your plugs to have a look at them? Is the cooling system full?
Old Oct 31, 2009 | 09:50 AM
I checked the oil with the dipstick, not milky. I did not notice any leakage of any kind. Did not check the plug. So is the thermostat not likely? System is full and clean
Old Oct 31, 2009 | 09:55 AM
It still is a possibility, but it pays to check everything over first.
When you replace the thermostat, also replace your radiator cap.
Old Oct 31, 2009 | 10:26 AM
Thanks for the advice... I'll pull a plug then replace the thermostat and cap if i see no issues
Old Nov 1, 2009 | 11:12 AM
Default Still issues coolant system related issues
filled with coolant, boiling sound in or around the water pump. leaking (slow steady drip) under front end of engine. skid plat makes it difficult to pinpoint the origin of the leak. Should the next step be a pressure test?
Dylan Dupasquier
15
Jul 24, 2014 10:14 AM
m3ch
Dec 14, 2010 09:46 PM
fm5050
Mar 22, 2010 04:55 PM
Icon13
Feb 18, 2010 12:54 PM
vaportrail
14
Jan 11, 2010 11:12 AM
