Overheating Issue
Old Sep 6, 2014 | 09:56 PM
SeniorC's Avatar
SeniorC is on a distinguished road
Default Overheating Issue
I have a manual 2 door 2000 4.3 l v6 blazer. It overheats after about 5 minutes of driving. I flushed oil/coolant and replaced it along with a new thermostat but it still seems to over heat. It also seems to not pull any coolant from the overfill reservoir, I put the new coolant straight into the rad. Any ideas on what would cause this?
Old Sep 6, 2014 | 10:07 PM
jmparker82's Avatar
jmparker82 is on a distinguished road
When you start it and run it for a few minutes go check the radiator and hoses. If they get soft and collapse in on them selves that could be the reason. Also if the motor is starting to over heat but the radiator is still cool then your water pump may be out.
Old Sep 6, 2014 | 10:08 PM
jmparker82's Avatar
Thats a start. Post what you find out from this and hopefully can find the issue with minimal cost.
Old Sep 7, 2014 | 10:56 PM
SeniorC's Avatar
Turns out it had a small crack in the rad.
Old Sep 10, 2014 | 01:00 AM
WildDomesticTabby's Avatar
WildDomesticTabby is on a distinguished road
I'm willing to bet that yours wasn't an OEM radiator unit. Only the OEM ones from AC Delco seem to last on these trucks. BTW: if I were you I'd replace the lower radiator hose too just for..funsies. In my experience, replacing an old lower rad hose makes a vehicle run a little cooler, but YMMV
Klturi421
May 9, 2012 05:43 PM
GeoBlazer
23
Oct 23, 2011 08:57 AM
lost113
Aug 2, 2011 10:11 PM
ontheplains
Aug 28, 2010 08:19 PM
bobditts
Jan 31, 2009 11:18 PM
