Oxygen Sensor / Vacuum Leak
Hey guys. I've got a code for sensor 1 bank 1. I've replaced the sensor twice and still get the code. I've heard this can also mean I've got a vacuum leak somewhere. Could you tell me which (if not all) vacuum lines would cause this? Or which lines would be a more probable cause for the code? I basically just need some help starting in the right direction.
Thanks,
Steve
Thanks,
Steve
yea sounds like an vac related Id start by the distributor and follow all the vac lines till you find the issue.
Edit: also this should help you
P1133 - HO2S Insufficient Switching Bank 1 Sensor 1
steelcityneal
Jan 10, 2010 09:23 PM
