P0155 2002 Blazer
Old Aug 26, 2024 | 09:03 AM
Dabbs24's Avatar
Dabbs24 is on a distinguished road
Default P0155 2002 Blazer
My son's car is shooting a code for P0155 bank 2 sensor 1. We've changed the o2 sensor, checked fuses and wiring, replaced gas cap, and the engine coolant temp sensor. We can not get this code to go away. Any insight to other things that could trigger this code?? Need emissions inspection done on it asap and it currently won't pass.
Old Aug 26, 2024 | 02:55 PM
GeorgeLG's Avatar
Year and model?
George
Old Aug 26, 2024 | 02:59 PM
GeorgeLG's Avatar
While I am waiting for that info, that code is for the O2 sensor heater circuit which does involve the sensors heater coil but also the power and ground sources as well as the wiring and pcm control, not just the sensor. After year and model I can help you with diagnosis.
George
Old Aug 26, 2024 | 03:01 PM
Dabbs24's Avatar
George
2002 Blazer LS
Old Aug 26, 2024 | 11:27 PM
GeorgeLG's Avatar
The PCM has determined that it takes too long for the O2 sensor on the passenger side in front of the cat to come up to operating temp. This cause for this is either:
  1. Exhaust leak
  2. Bad sensor heating element
  3. Bad wiring to the sensor heater
  4. Poor quality power or ground being supplied by the PCM
  5. PCM failure
I would check for exhaust leaks and then test the heater circuit by unplugging the connector on the sensor and placing an old school incandescent test light across the lt grn and lt grn/wht harness wires and seeing if you get a solid strong test light at key on.
George
thomp
Oct 14, 2019 12:46 PM
blanco36
Apr 15, 2014 12:28 PM
Dobe Rottie Gang
Dec 6, 2013 10:04 PM
rlbates60
Oct 7, 2010 05:56 PM
ultraz
Dec 26, 2009 02:33 PM
