P0300 Error Code and rough idle.
Old Sep 21, 2015 | 06:23 PM
reevesjo's Avatar
reevesjo is on a distinguished road
Default P0300 Error Code and rough idle.
2002 Blazer, 4.3L, 4WD, AC. I had problems earlier with #4 Misfire and80# compression, so I found a bad head gasket. After replacing the head gasket, it ran much better with no errorcodes. When trouble shooting earlier, Iremoved the upstream oxygen sensor, I left it plugged in and just hanging. NOW, after replacing the same oxygen sensorin the pipe, it runs rough and I get a P0300 Random Misfire. There is no Oxygen Sensor error code. Question...Could my problem be thecatalytic converter? How can Itell?? Any suggestions??
Old Sep 21, 2015 | 06:27 PM
reevesjo's Avatar
Default Crazy laptop keyboard
So, I typed this in Microsoft Word and pasted it. It was perfect in Word, but here, it skips spaces etc. Hope you can make sense of it.
Old Sep 21, 2015 | 08:17 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
The O2 sensor may have been damaged while left hanging there. A bad O2 sensor can give you a multiple misfire code. It's worth checking it anyway...
Old Sep 22, 2015 | 11:34 AM
reevesjo's Avatar
Default Can it be the Catalytic Converter????
CWBDDSPC I really was not driving it with the O2 sensor hanging,
just setting in the garage. However when I remounted it, the P0300
reappeared. Now, I tried removed all 3 or the O2 sensors and left
them plugged in but just hanging. The engine runs smoother and
when I accelerate to 2000rpm, everything gets even better. The check
engine light does not come on now, but the code reader says I have
a P0300 Random Engine Misfire "PENDING" message. There never
has been an O2 failure message. Still wondering if the catalytic
converter is the problem. No error message to indicate that. Any
cheap way to determine? Somewhere, I read that takes expensive
equipment.
Old Sep 22, 2015 | 05:43 PM
CWBDDSPC's Avatar
If the O2 sensors were simply hanging from their wires, they may be damaged from simply hanging there. I realize they are not THAT heavy, but the little wires are not designed to support the O2 sensors either...
Also, perhaps damage was done to the wires or sensors while removing or installing them
Do you have reason to suspect you have a problem with the catalytic converter? From your original post, everything seemed fine until you needed a head gasket correct? Nice job diagnosing that! Then everything was good until you got the multiple misfire code. You mentioned recently working on a $30 sensor that could be a cause the 0300 code. It seems logical to me to rule out the O2 sensors before blaming the cat. You can test the O2 sensors with a DMM and a heat source. If you are able to rule those out, great job again! Then there are a ton of posts on the forum about the P0300 code. There is one in particular that leads you down the troubleshooting path quite well. I would look for that and start ruling things out. Yes, a bad catalytic converter CAN be a cause, but it wouldn't be my first guess in your situation. And guessing gets expensive...
jack hammer
Dec 4, 2013 04:36 PM
palmer96
Jul 16, 2013 08:40 PM
CabraMonster
Oct 24, 2011 05:51 PM
bkw
18
Jun 6, 2011 09:07 AM
98blazr
44
Aug 21, 2009 01:17 AM
