P0300 p0404
Old Nov 16, 2018 | 06:08 PM
Bryan Emundo Zhanay's Avatar
Bryan Emundo Zhanay is on a distinguished road
Default P0300 p0404
Bought blazer with p0305 misfire in cylinder 5. Well now its saying p0300 and p0404 which is multiple cylinder misfire and EGR valve. The previous owner replaced all the spark plugs, plug wire, distributor cap and rotor. Wondering what it could possibly be and where to start
Old Nov 16, 2018 | 06:29 PM
Need more info... What year at least?
Old Nov 16, 2018 | 06:36 PM
I’m sorry yeah it’s a 2000 it’s got about 96,000 miles on engine
Old Nov 16, 2018 | 07:02 PM
I would start by checking fuel pressure. Assuming your 2000 has the original (or at least original style IF it's been replaced before) fuel injector "spider" assembly, it has what are called a "poppet" style injectors for each cylinder. They require a specific amount of fuel pressure before they will "fire" off and inject fuel into the intake runner they're pointed at. If the injector nozzle either gets partially internally clogged (from bad or dirty gas) or the fuel pump is beginning to go, OR the fuel pressure regulator that is mounted to the assembly inside the intake starts to leak, fuel pressure at the poppet injectors can drop and cause them to not operate correctly and can easily cause multiple cylinder misfires.
Just my $0.02
Old Nov 18, 2018 | 10:25 AM
Also take off the EGR valve and make sure there's not a piece of carbon stuck in it and holding it open.
Protonicx
May 22, 2018 12:31 AM
AlwaysWanted1
Feb 25, 2018 10:22 PM
loganreeves
Performance & Brainstorming
Mar 30, 2009 10:13 AM
EuroGoldLS
Detailing
Jun 5, 2007 01:07 AM
