p0302 and mass air flow code
Old Oct 11, 2015 | 11:19 AM
blazer0386's Avatar
blazer0386 is on a distinguished road
Default p0302 and mass air flow code
I have replaced the cam sensor to clear up p0300 and bad cam sensor code that is gone put new double platinum ac delco plugs and the 8mmwires still have p0302 code has a shake miss at idle and on take off but after 2000 rpm it has plenty of power on interstate it loses power badly unless passing gear the miss gets worse when the engine is warmer oh forgot to mention its a 2003 Chevy blazer 4.3 auto 4x4 126000 miles on it thanks in advance
Old Jun 13, 2016 | 03:47 PM
joemathhead's Avatar
joemathhead is on a distinguished road
Default Problem solved?
Blazer0386, the problem you described is nearly identical to what I am experiencing, did you get a resolution to your problem and if so, what was it?
Juggalo1003
Jun 8, 2013 11:26 AM
O_P_PLaya
Headers, Intake, & Exhaust
Sep 2, 2007 01:22 PM
alphagtp
Feb 13, 2007 03:18 PM
chevyrocksu
Nov 15, 2006 10:44 AM
abmoto4
Aug 31, 2006 07:52 PM
