P0305 to P0300 after MPFI upgrade
Old Feb 23, 2016 | 09:28 AM
tneil17's Avatar
tneil17 is on a distinguished road
I'll check the pins really quick before I head to harbor freight. Thanks for heads up on the app and thanks to everyone for their help so far!
Old Feb 23, 2016 | 10:25 AM
LesMyer's Avatar
You came to the right place!
Sounds like Captain has got this one, so I'll back off and provide help if needed with using Torque Pro and/or Car Gauge Pro to read the desired things. I think I have more experience than he with these specific Android apps, but not necessarily with the actual diagnostic strategy. Take it away Captain and I'll help where I can.
Old Feb 23, 2016 | 10:30 AM
LesMyer's Avatar
You do know you can get a loaner fuel pressure gauge from most auto parts stores like autozone and advance auto parts (with deposit)? To me it beats buying one, and they are usually pretty nice gauges.
Old Feb 25, 2016 | 07:55 AM
tneil17's Avatar
Could an improperly done "throttle body mod" cause the problem? Reset the ECU and the idle is around 1,000-1,250rpm and still has cylinder 3. Didn't notice the throttle body was missing the diverter until I thought about it.
Old Feb 25, 2016 | 09:04 AM
What did you do to reset the PCM? Throttle body mod will have no affect on individual cylinders, it does the same thing for each cylinder. Are you sure none of the injector "spider" lines were pinched when installing the plenum? Can be tricky adjusting the lines on the fuel metering block, especially #3 line. Idle speed is high, should be ~550 rpm. If the metering block is not fully seated up into the plenum, the O ring will not seal, causing a vacuum leak, high idle, and lean misfires.
BlazerHeadaches
Mar 31, 2019 11:53 AM
gregl316
Mar 7, 2011 03:10 PM
theeviltwinn
Oct 25, 2009 10:06 PM
vaportrail
Aug 16, 2009 06:15 PM
jthistle
Engine & Internal
Jan 24, 2007 11:06 PM
