Please help!!!!!!
Old Sep 7, 2013 | 10:05 PM
linsgm's Avatar
linsgm is on a distinguished road
Default Please help!!!!!!
just did the head gaskest on 92 s10 4.3 vortec!!!! SOUNDS AND RUNS LIKE (****) gave the top end kit to machine shop thought they could use parts from it like (VALVE STEM SEAL) since i WAS expecting the valves to be done along with the heads being checked paid $125.00 BUT LOW AND BEHOLD inside the kit was STIIL 12 VALVE STEM SEALS!!!!!
AM I MISSING SOMETHING IN THIS EQUATION?
what should have been DONE or POSSIBLY NOT DONE?
I BOUGHT EVERYTHING NEW AND IT SOUNDS AND RUNS LIKE ****!!!!
Old Sep 8, 2013 | 06:01 PM
newguy's Avatar
go back, thats what you should do
Old Sep 8, 2013 | 06:56 PM
rexazz2's Avatar
its one of those clarification deals
I suspect $125 is to cheap for a valve job and check
Generally if they are magna fluxing iron heads they are removing the valves to check for cracks in the ports
They at least should have put in the new valve seals in for reassembly if they were there
there is a possibility that if they pulled the valves and didn't machine them that they mix them up in reassembly
Did they plane the head gasket surface ?
Old Sep 9, 2013 | 03:46 AM
linsgm's Avatar
yes they did and im just going to dump it been night mare since ive had it tyvm for replying back
opposedforces
Sep 1, 2011 02:59 PM
BlazerPunisher
Mar 23, 2009 05:47 PM
rogggg1020
Nov 11, 2008 08:05 AM
blazin4eva
Feb 26, 2005 12:04 PM
blazin4eva
Jan 27, 2005 02:02 PM
