PLZ HELP 2001 Jimmy sputtering stalling
Old Feb 17, 2013 | 08:16 PM
Jimmy76's Avatar
Jimmy76 is on a distinguished road
Default PLZ HELP 2001 Jimmy sputtering stalling
Hello, I am very new to this forum. Am I desperate need of help! I have a 2001 4.3 Jimmy. I will start from the beginning... Just before Christmas the intake manifold gasket went on it "days before Christmas" so we sent it to a shop to have it repaired. We got the truck back and the temperature gauge didn't work... So we took it back to the shop they got it working in seconds lol. Sigh. After that it was having trouble starting in the mornings. I we live I am Canada "burr" lol. First few days it was 5 cranks, then it was 10 cranks... New battery and 20 cranks. Then it would run fine for the rest of the day! Then it would not start at all. We had to get it towed home! I pour gas down the throat and it started right up! Then stalled right after! I have checked the normal things fuel pressure is good... Drops fast when not running thoug . Replaced the fuel filter "no change" . The old one seemed cleaned. It will start and die every time... I have since found if I feather the pedal it will spit and sputter sometimes even clean itself up and if I keep idal above 1500 it will seem as though it runs great. Anything under and it will start the spit and sputter all over again. The truck ran great up until the intake manifold gasket was replaced... I really need help! I am banging my head off the truck trying to figure this out. This is the girlfriends truck... Not sure if Iam leaving anything out PLZ HELP
Old Feb 17, 2013 | 08:36 PM
swanman35's Avatar
swanman35 is on a distinguished road
I really don't know too much myself, but I do believe that a problem with the egr valve can cause that problem. Maybe try cleaning it and see if it helps? A new gasket for it is only a few dollars so it is worth a try.
Old Feb 18, 2013 | 09:21 PM
Jimmy76's Avatar
Bump nothing
Old Feb 22, 2013 | 05:12 AM
Jimmy76's Avatar
Doesn't anyone have any ideas?
el cheapo
Engine & Internal
Aug 15, 2012 12:34 PM
pfunknasty
Apr 23, 2012 10:36 AM
mobcittty
May 17, 2011 03:53 PM
gagirl320
Aug 7, 2010 10:10 AM
josh77888
Jul 13, 2010 08:14 AM
