pompa benzina del blazer chevrolet
Old Feb 26, 2019 | 12:49 AM
Marione's Avatar
Marione is on a distinguished road
Default pompa benzina del blazer chevrolet
Buon giorno avrei bisogno di sapere quanti bar è la pompa carburante del blazer 4300 v6 del 2001 grazie
Old Feb 26, 2019 | 06:25 AM
don james's Avatar
don james is on a distinguished road
"Good morning I need to know how much bar is the fuel pump of the 2001 blazer 4300 v6 thanks"
I don't understand the "bar' maybe someone else will.......
Old Feb 26, 2019 | 06:31 AM
cleburne red's Avatar
Isn't bar a way of measuring pressure?
So the fuel pumps put out around 80-100 psi, roughly, quick internet maths tells me that's about 5 to 6.8 bar
Old Feb 26, 2019 | 06:37 AM
Bar is a unit of pressure measurement.
The pump has a maximum pressure of ~70 to 100 psi (4.8 to 6.9 bar). The fuel pressure regulator located in the engine will regulate the fuel pressure at 60 to 66 psi (4.1 to 4.6 bar).
Some have observed fuel pressures as low as 55psi (3.8 bar) on a properly running engine which could be attributed to gauge error, but if the pressure were actually this low it could affect the operation of the pressure actuated poppet nozzles used in the stock SCFI fuel system. A common upgrade is the MFI spider which moves the electronic injector out to where the poppet nozzles are located in the SCFI setup, eliminating the problematic poppet nozzles.
Google Translate to Italian:
La pompa ha una pressione massima da ~70 a 100 psi (da 4,8 a 6,9 bar). Il regolatore di pressione del carburante situato nel motore regolerà la pressione del carburante da 60 a 66 psi (da 4,1 a 4,6 bar).
Alcuni hanno osservato pressioni del carburante a partire da 55 psi (3,8 bar) su un motore correttamente funzionante che potrebbe essere attribuito a un errore del calibro, ma se la pressione fosse effettivamente così bassa potrebbe influenzare il funzionamento degli ugelli a fungo azionati a pressione utilizzati nella SCFI di serie sistema di alimentazione carburante. Un aggiornamento comune è lo spider MFI che sposta l'iniettore elettronico verso il punto in cui gli ugelli a fungo si trovano nel setup SCFI, eliminando gli ugelli a fungo problematici.
Old Feb 26, 2019 | 09:49 AM
Marione's Avatar
OK thank you
Old Feb 26, 2019 | 02:40 PM
Marione's Avatar
OK grazie mille
jimmy2468
Mar 4, 2012 01:48 PM
Blazer_LT
Nov 10, 2011 07:29 PM
95BlazerLt4wd
Lifting Tech
Mar 4, 2008 08:58 PM
mikehillis1@yahoo.co
Suspension Tech
Sep 24, 2006 07:21 PM
powwowblazer
Suspension Tech
Jun 26, 2006 05:22 PM
