614blazer |
02-14-2012 03:24 PM |
possible bottom end knock mystery
ok so my 98 blazer is having a knock now many new parts now this. how it all started drove it to a store about 30 min away and got a call my mom got in a wreck so i rushed to see if she was alright going about 80 on freeway i know illegal. when i got off the freeway exit and went to take off from a stop light i heard knocking and i can feel the knock when i put my hand on the lower intake and gets worse upon accel.. it never done this. long story short check if my mom was alright went home and it knocked only when i gave it gas around 1,500 rpm and above loud knock. let go of the gas rattle knock then at idle nothing. well i had a big ? above my head. well the next day i went to start it loud knock at idle and gets louder upon accel. then i let off gas and i hearing a squeaking right where the trans and motor meet. and i took the cap off the bell housing with it runing and the flexplate/torque converter wobles slightley. my mechanic told me to check the torqce converter bolts they was tight now another mechanic told my check the flexplate to see if its broken- cracked- or losse. and he also said it could spun a rod bearing. wth im confused need help ASAP is the motor shot/ replace it or can i save it and rebuild the bottom end. help. need to get to work and have a baby on the way......??? sorry for long thread just entering as much info a possible..
