Power to coil none coming out 96 4.3 csfi
Old Jun 13, 2010 | 09:35 PM
ecmusicman's Avatar
ecmusicman is on a distinguished road
Default Power to coil none coming out 96 4.3 csfi
I just got done putting my motor together and i did everything by the book I went to start it up and nothing, so I pulled a plug and no spark. I went through every thing with a test light and I am gettng power going to everything so I have elemated the thought of a bad ground. When I got to the coil I found that I was getting power in but none coming out wich leads me to the thought of a bad coil, but I had the module on it tested and that was ok but there is no way of testing the coil itself. I guess what I would like to know b4 I blow 35 bucks on a new one if there is any thing else that it could b. I would b very greatfull of any input I have a wife and 2 kids and don't have very much money to spend on things I don't need. Thanks,Eric
Old Jun 16, 2010 | 09:41 AM
ecmusicman's Avatar
Well I had my brother inlaw test out the coil in his truck and it is fine so now I really don't know what is wrong SOMEONE PLEASE H E L P !!!
Old Jun 16, 2010 | 11:29 AM
rriddle3's Avatar
Originally Posted by ecmusicman
I just got done putting my motor together and i did everything by the book I went to start it up and nothing, so I pulled a plug and no spark...
Well, the only things between the coil and the spark plug is the distributor and plug wires. Have you verified the validity of those items?
Old Jun 16, 2010 | 11:48 PM
ecmusicman's Avatar
All new!!
Old Jun 17, 2010 | 10:05 AM
ecmusicman's Avatar
The only thing that is not new is the crank sensor but I do have 2 of them unless my luck is very bad I am sure 1 of them works. Also does anyone know if I have a bad conection at the starter if that would cause it not to spark??
Old Jun 28, 2010 | 11:16 AM
ecmusicman's Avatar
Can anyone help me ?????
Old Jun 28, 2010 | 11:26 AM
Are there any codes? Have you hooked the truck up to a full feature scan tool to monitor the sensors? Are both the CMP and CKP sensors connected properly? Any damaged wiring?
Old Jun 28, 2010 | 11:31 PM
Hanr3's Avatar
Get your ICM tested. It controls spark from coil to distributor.
JavierEscalonJr
Oct 14, 2020 11:38 PM
blainenbecky
Mar 9, 2013 10:38 PM
Lancealot
Feb 22, 2011 07:34 AM
chipjumper
Jun 17, 2010 12:24 PM
SDimeBlazerlady
Jan 27, 2007 05:58 AM
