Power issue... TPS??
Old Jun 21, 2017 | 10:32 AM
92_S10_4x4's Avatar
92_S10_4x4 is on a distinguished road
Default Power issue... TPS??
I have been having a consistent power issue, and got it MOSTLY fixed... replaced the ECM and took it to get timed properly, and now the power itself is great, BUT it randomly likes to act like the gas pedal is not engaging. Also, the oil gauge randomly drops right the bottom, even with a new oil pressure switch. I am thinking it is either a fuel/oil pressure problem, or the throttle position sensor. I will list all new parts and fixes, please give me your thoughts!
1992 Chevy S10 Blazer 6cyl 4.3L TBI
• spark plugs and wires
• distributor cap and rotar
• air, oil and fuel filters
• fuel pump and strainer
• fuel pump relay
• thermostat
• pressure radiator cap
• oil pressure switch
• coolant sensor (?)
• PCV valve
• EGR valve
• MAP sensor
• starter
• ECM
• timing adjusted
*NOTE: It is currently missing the catalytic converter and O2 sensor, until I can afford to replace the entire exhaust system with a better one.
HELPFUL REPLIES ONLY, PLEASE!!!
THIS IS NOT A "MULTIPLE POST"!!!
Old Jun 21, 2017 | 02:52 PM
Rusty Nuts's Avatar
Your TPS operates at 0-5 volts DC. You tube has testing procedure videos. A basic multi meter is all that's required.
ARk_John
Apr 12, 2011 07:20 PM
Brianator99
Oct 18, 2010 10:53 AM
wwild0471
Oct 2, 2009 01:16 PM
david7w5
Sep 11, 2009 08:41 PM
