Problem starting in the rent
Old Apr 17, 2021 | 01:41 AM
Travis Lee's Avatar
Travis Lee is on a distinguished road
Default Problem starting in the rent
Everytime it rains I go out to start my Blazers it doesn't want to start I'm assuming there's moisture getting into the distributor underneath the cap has anyone had this problem and if so how how did you fix it? Thanks in advance for any help
Old Apr 18, 2021 | 02:04 AM
There are too many possibilities. The Blazers are not commonly known to get moisture into the distributor. If so it may already be corroded internally.
If the truck is parked under trees the gutter like edge under and around the hood can overflow and water seep into the engine wiring and as well the distributor.
Contributing is normally a missing joint along the u-profiled edge on the firewall side.
Would need to look where water enters the engine bay. Still other possible places that can get wet and cause a non-start.
Also check distributor cap itself if cracked.
Annie
16
Nov 17, 2012 07:02 AM
614blazer
Sep 24, 2011 08:30 AM
fstmalibu
Feb 6, 2011 12:13 PM
sarahj
Mar 7, 2010 11:28 AM
99BlazerZR2
May 24, 2008 08:46 PM
