Question about a pressure control solenoid for 4L60E
Old Aug 30, 2013 | 05:12 PM
Kilo's Avatar
Kilo is on a distinguished road
Originally Posted by tfcman
OK, Reverse 1 and 2 shift fine. When it is time for 3rd, it does not engage and revs like it is in neutral.
yea your 3rd gear clutch pack is shot time to rebuild....because you are saying you have 1,2, no 3rd and I didn't see anything about 4th which is overdrive anyway your 1-2 solenoid is in charge of changing from 1st to 2nd then once you run 2nd out the 2-3 solenoid changes it to 3rd so if you have 1st and 2nd and then it has a neutral condition with motor revving then the solenoid is doin its job its ust the clutch pack is fried so there is nothing to engage
Old Aug 30, 2013 | 05:15 PM
Kilo's Avatar
you could adjust the pressure but as swartlk said it probably would cure nothing it would just mask the problem or cause others so...kinda sounds like forward clutch pack may be slipping or fried
Old Aug 31, 2013 | 09:17 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Question
Go guys with my problem of not having a first gear shift is clutch packs are about fried or is there any other things I can look into to make this last a while longer.My transmission man said that the piston on the side I can drill a hole and put stiffer spring in it to help.Anyone ever did this?
Grayson100944
Dec 17, 2013 02:42 PM
dj00140
Feb 27, 2011 02:59 PM
Tony H
Jan 21, 2011 10:11 AM
Tony H
Feb 23, 2010 08:09 AM
god_zilla00000
14
Jan 5, 2010 05:26 AM
