-   -   Question on changing plugs 1995 Blazer 4.3 (https://blazerforum.com/forum/engine-transmission-35/question-changing-plugs-1995-blazer-4-3-a-83376/)
NRA Life Member Dec 16, 2013 09:09 PM
We are changing plugs on the 1995 4wd Blazer. All plugs are changed except for cylinder 3. It has the steering shaft right in the way and we can't get a wrench on it. We can put a spark plug socket on the plug but then there's not enough room to get the ratchet on the back or a wrench on the back of the socket. Any tricks for getting this plug out? Use a normal socket? All the rest are done but this one.
Thanks,
Larry
chris015 Dec 16, 2013 09:18 PM
5/8 socket with knuckle,or pull the shaft
NRA Life Member Dec 16, 2013 09:53 PM
We thought about the socket after dinner tonight so I might send the boy back out to try that. Didn't look at pulling the shaft though. Is it as tough to get out as everything else on this infernal truck????
Thanks for the reply
cleburne red Dec 17, 2013 05:48 PM
I disconnected the shaft at the steering box. took maybe a minute. One or two bolts, I can't remember, but it was easy. either have an assistant hold the shaft up out of the way, or wire it back, which is what I did.
Some people claim to be able to get a socket on there, but I couldn't. removing the shaft was easiest for me
Tenagator Dec 17, 2013 06:09 PM
I just did mine a few weeks ago, I used the spark plug socket with a swivel on the end then a long extension, it worked out fine.
Vader Dec 17, 2013 06:25 PM
When I did mine I could do all of them but #3. What a pain in the a**! I ended up not being able to disconnect the steering shaft so I just took it to a mechanic I knew and had him do the last one. Disconnecting the shaft is supposidly the easiest way.
NRA Life Member Dec 18, 2013 08:36 AM
Thanks for the inputs everybody. My son who has skinnier hands than me was able to get a standard 5/8 socket on that plug and barely have room for the swivel. He got it changed. We changed out the Distributor cap and rotor also. The wires were still pretty new so they stayed. It is running great now. Thank you everybody!!
swartlkk Dec 18, 2013 08:39 AM
For future reference, we have an entire thread in the Tech Article (DIY) section devoted to this topic --> #3 Spark Plug Removal
NRA Life Member Dec 18, 2013 03:26 PM
That's good stuff right there. I did a search early on but that one didn't come up. Thanks for the link.
nl_dwrd Dec 23, 2013 06:19 PM
I heard that there is a socket you can buy to change that plug
