Question where to make the cut.
Old Dec 5, 2012 | 02:23 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Question Question where to make the cut.
A while back I screwed up when I put my trans in,while it was lowered I forgot to put the lines on.
Theres not enough room for me to get to it underneith.So Im going to make a cut through the floor board unless theres an easier way?
So if worst comes to worst and I have to make the cut where?
Is it on the hump before the seats or where?
Old Dec 5, 2012 | 05:24 PM
neo71665's Avatar
I would remove the body mount bolts on that side, loosen (don't remove) the other side, jack the side of the body up, set 4x4s blocks between the body and frame, lower body down. That should give ya the needed room without cutting a hole in the floor to patch.
Old Dec 5, 2012 | 05:36 PM
newguy's Avatar
Is the y pipe off? shouldnt be that hard with it off
Old Dec 5, 2012 | 05:56 PM
I dont quite have the room the Blazer is inside 10x20 building.With an 8 cealing.
NewGuy no the Y pipe isnt off
Old Dec 5, 2012 | 06:27 PM
newguy's Avatar
Y pipe is the problem isnt it?
Old Dec 5, 2012 | 10:00 PM
Only if its in the way of getting to the trasmission lines.If so I can take it off.Mind you Im in a much tighter space than before.
Old Dec 6, 2012 | 08:03 PM
abig84's Avatar
yeah i always make sure i put the trans lines on before the exhaust goes back on. all the room in the world with the ypipe out of the way
Old Dec 7, 2012 | 09:29 AM
Question
So can anybody answer this question?If Im going to make a hole in my floor board is it the hump right before the seat or is where the ceneter council is?I have already made up my mind this is what Im going to do.At this point theres no other way around it.
Old Dec 7, 2012 | 10:04 AM
coolasice's Avatar
coolasice will become famous soon enough
on my truck I was able to get everything connected with just the y-pipe hanging down (disconnected from the manifolds).. it was tight and I said quite a few choice words but I still got it connected.
Old Dec 7, 2012 | 11:22 AM
newguy's Avatar
Choice words always helps!
