questions about this process
Hello, I just purchased a 93 Blazer and I am having some of the same shifting problems that others are having. I followed a few of the links to the TV adjustment cable page and it scared the apples out of me. Is it really as it sounds or will I notice right away if I mess this up?
I have already put 500 miles in the five days since I purchased this thing and I don't want to make a little problem huge, but I usually do my own repairs.How easy is this? Vino PS if my wife sees me working on this new truck that i just spent our savings on, this will be my last post until I get out of the butt chewing chair. Vino |
Easy as pie and no you wont hurt anything doing it. You should notice if its adjusted correctly right away.
http://img245.imageshack.us/img245/1403/17131509.jpg |
OK this is done and now I idle at 2000 rpm. did I do something wrong or did the last owner makes some changes to over compensate for something?
It seems to shift a lot better (still not as good as hoped but better) but at 2000 rpm i can make it to work without the gas peddle. any ideas PS my adjustment tab had to pull up not push down how weird is that? is this becasue I have a full size blazer and not the s-10? |
Ok since than I have put the cable back to where it originally was. I will get with someone here locally but thanks
Vino |
