quick transmission question...
Old May 21, 2022 | 02:34 PM
pjdupont1's Avatar
pjdupont1 is on a distinguished road
Default quick transmission question...
will a 2005 chevy tahoe trans go into a 99 blazer 2dr 2wd vin w?
Old May 23, 2022 | 06:07 PM
Mods's Avatar
Probably yeah, May have to bring the torque converter over. check your bolt patterns. If its a 4L60E it absolutely can work. depending on the input shaft type, for the most part they are electrically compatible all the way through.
Old May 23, 2022 | 09:07 PM
pjdupont1's Avatar
thanks for the info. ive been searching for a good used one but have had no luck really. how can i know what im buying? dont really want to throw money away. drop the pan and look for metal on the magnet ??
Old May 24, 2022 | 07:01 PM
Mods's Avatar
inspect fluid condition, externally accessable seals such as the extension housing or transfercase adapter seals, driveshaft yoke seal (is inside a cup on the output shaft on 2WD models), Input shaft torque converter clutch fluid circuit seal (the only o-ring on the forward end of the input shaft), Fluid should be a cherry translucent red and smell like oil, not burnt ***. Look for grit (clutch material) and metal shavings/flakes/sparkles in the pan and fluid, as well as the magnet. and if possible get the mileage of the vehicle it came out of.
Gookdog69
Dec 21, 2016 02:30 PM
chuey_316
May 14, 2016 07:24 PM
joejiz
Aug 1, 2014 07:33 PM
96ProjectHighLife
May 26, 2010 11:49 PM
