Radiator drain petcock
How do I get the drain plug/petcock out to drain the radiator? I want to do a coolant flush, but I can't figure out how to get the plug out of the radiator. It's a weird, white plastic plug with no tabs or ears to grab onto in order to twist it out.
What I was planning on doing was running a flush chem like prestone, then hooking up a flush adapter to the heater hose with the tstat out and run it with the water running.
99 Bravada
99 Bravada
If it opens, a 1/4" ratchet head will fit inside and turn it. Still a pain to open and it takes FOREVER to drain... The Delphi replacement radiator I bought doesn't even have a drain...
I would say just pull the lower radiator hose
Chadoo951
Feb 13, 2008 02:05 AM
BTJustice
15
Jan 5, 2008 12:44 PM
FLcruising
Jul 4, 2005 02:51 PM
