Radiator help?
Old Nov 3, 2014 | 06:53 AM
joenov's Avatar
joenov is on a distinguished road
Default Radiator help?
I was replacing a transmission cooling line on a neighbors 2005 Trailblazer. I removed the 3/8" fitting from the radiator on the lower drivers side because it was damaged. The fitting had a beveled washer attached to it. The local parts stores had only the straight fittings with no beveled washer. I went to put one on and the piece that it threads in to went inside the radiator and coolant came pouring out. I put the old "beveled" fitting back on temporarily and all seems well. I guess my question is: Did I ruin his radiator? I see the purpose of the beveled washer, but is it normal for that piece to be pushed in to the radiator?
Thank you for any insight you can offer.
bigdaddykane93
Jan 4, 2010 12:03 PM
Ayieka
May 16, 2009 08:34 PM
afrench690
15
Apr 17, 2008 05:46 PM
Maldo15d
Dec 4, 2007 08:00 PM
Hanr3
Engine & Internal
Sep 8, 2006 02:31 AM
