Random misfire/excessive fuel consumption
Old Nov 23, 2011 | 05:58 PM
DMShorkey's Avatar
DMShorkey is on a distinguished road
Unhappy Random misfire/excessive fuel consumption
We are at it, again. Have replaced the MAF. New fuel filter. Spider and injectors have tested fine (are not leaking). New symptom = when we disengage the battery for a bit - all codes clear (of course) and Blazer runs like a top for 50 miles....then - BHAM! Misfire and excessive fuel consumption. There is no fuel leak as from a line....but there is a raw fuel smell (fuel is just dumping down the cylinders after 50 miles of all clear). Does anyone have ANY ideas out there that may be causing this??? We are stumped and at a loss. 1998 v6, vortec 4.3. Thanks!
Old Nov 23, 2011 | 08:01 PM
pettyfog's Avatar
So, by inference, you can reset it and drive another 50 miles by simply disconnecting battery and clearing those codes...
Whatever they are
.... dunno. maybe put a switch on the ECM1 fuse?
There MIGHT be a chance.. long shot for sure.. that those codes might give us a clue.
Old Nov 24, 2011 | 05:59 AM
DMShorkey's Avatar
Codes are...PO102, PO154, PO174, PO300, PO440, P1153. (sorry didn't post those - did it in an earlier thread and must have thought I did here...) Would the O2 sensors cause excessive fuel dumping???? It just seems so strange that the Blaze drives great for 50 miles after all codes have been cleared, and then causes trouble, again.
Xenon
95
Feb 8, 2012 03:07 PM
JNR004
May 17, 2009 09:42 AM
Davis83
Performance & Brainstorming
15
Dec 7, 2008 03:59 AM
spiritwild
Feb 10, 2007 07:40 PM
Ahmad
Engine & Internal
16
Mar 21, 2006 12:20 AM
