random misfire wtf??? please someone help
Old Mar 29, 2015 | 05:58 PM
Open loop again, gotta be closed loop for accurate results. Those are all freeze frame data, it tells where everything was when the DTC was set. We need to have real time closed loop data, mainly fuel trims, at 2K rpm.
Old Mar 29, 2015 | 11:58 PM
blazerhelp01's Avatar
blazerhelp01 is on a distinguished road
Thank you Captain Hook. will try this again... Thanks again for all the help.
Old Mar 30, 2015 | 06:43 PM
Default closed loop
heres new results with closed loop.
MIL DTC P0304 Cylinder 4 Misfire Detected View Stored Codes P0304 Cylinder 4 Misfire Detected View Pending Codes P0304 Cylinder 4 Misfire Detected View P0335 Crankshaft Position Sensor Circuit Malfunction View Freeze Frame Information
Parameter Description
Results
DTC for which Freeze Frame was Stored
P0304
Fuel System 1 Status
Closed Loop
Fuel System 2 Status
Closed Loop
Calculated LOAD Value
23.92 %
Engine Coolant Temp
190.40 °F
Short Term Fuel Trim - Bank 1
-10.16 %
Long Term Fuel Trim - Bank 1
17.97 %
Results
Short Term Fuel Trim - Bank 2
-1.56 %
Long Term Fuel Trim - Bank 2
10.94 %
Intake Manifold Absolute Pressure
20.13 inHg
Engine RPM
1,951.75 rpm
Vehicle Speed Sensor
29.83 mph
Air Flow Rate Mass Air Flow Sensor
5.08 lb/min
Absolute Throttle Position
26.67 %
Monitor Status
Monitor Name
Monitor
Icon
Status
MIL (Check Engine Light)
ON
Misfire Monitoring
Complete
Fuel System Monitoring
Complete
Comprehensive Component Monitoring
Complete
Catalyst Monitoring
Not complete
Heated Catalyst Monitoring
Not Supported
Evaporative System Monitoring
Not complete
NMHC Monitoring
Not Supported
Monitor Name
Monitor
Icon
Status
NOxAdsorber Monitoring
Not Supported
Secondary Air System Monitoring
Not complete
Oxygen Sensor Monitoring
Not complete
Oxygen Sensor Heater Monitoring
Not complete
EGR System Monitoring
Not complete
Boost Pressure System Monitoring
Not Supported
Exhaust Gas Sensor Monitoring
Not Supported
PM Filter Monitoring
Not Supported
Thanks so much...
Old Mar 30, 2015 | 06:58 PM
Must be closed loop, real time data, not freeze frame.
Old Mar 30, 2015 | 09:31 PM
not sure how to tell if its in open or closed loop. it always says freeze frame. ill delete the codes every time to make sure they are present codes. it says closed loop.? ill drive it for like 20 miles. i just cut off my cat because it was clogged. thought maybe had to do with whats wrong with this thing. could that maybe keep it from going to closed loop.
Did fuel pressure test pressure only dropped 3 pounds. But only had top pressure of 46 pounds. Not sure if this means anything. pressure held. Thank you
Old Mar 30, 2015 | 09:36 PM
Aha, way back in post #3, I mentioned fuel pressure. Use this link and post all 4 numbers: https://blazerforum.com/forum/2nd-ge...eakdown-88305/
b_didddy510
Mar 29, 2019 06:57 AM
kdawg1354
Feb 26, 2013 09:55 PM
shanegreen
Apr 22, 2012 10:25 AM
hunterman18
13
Jun 22, 2010 07:55 AM
jdblazer
Dec 20, 2006 12:58 PM
