Originally Posted by Trip coverage
(Post 707990)
Would I do any damage to "the blazer"
If I drove her to AutoZone with a busted cat. |
Thanks for helping me out
Originally Posted by odat
(Post 707992)
prob not - if back pressure got too high if the internals come's further apart it would just quit running due to lack of exhaust flow .......
(Post 707993)
Would the cat breaking up cause the rearend to shake???
Thank you for your help.
(Post 707997)
Depending on what you mean by shake but A multi hard miss prob would
One more thing this all started with no warning. It almost seems like someone sabatoged my truck. |
(Post 708101)
just got it out of the exhaust shop. No symptom have been repair. With the exception of the rattle and the vibration of the rearend. It is still missing and popping.
Originally Posted by cleburne red
(Post 708108)
OK, so the exhaust shop replaced the cat? And now the rattle and vibration is gone, but it still misses and runs rough?
Took it to AutoZone. It threw 5 codes 2 0300 0171. And 2 0101. The code reader says the blazer needs a fuel regulator. Which makes sense because half of air filter is missing. Me and buddy are now tear apart the carb(injectors) to replace this part. Hope this fixes it. |
Did you actually check the fuel pressure, or are you just throwing parts at it? Fuel pressure is super easy to replace, and can determine if the injectors or pump is at fault
This is what was recommended.
Don't know. |
If it helps we are in a full tooled logging shop.
I work in the logging industry. I have access to a full tooled shop. |
And all the computer readers are locked up. Don't have access to those.
