Rattling noise coming from exhaust.
Old May 2, 2019 | 02:51 AM
odat's Avatar
Originally Posted by Trip coverage
Would I do any damage to "the blazer"
If I drove her to AutoZone with a busted cat.
prob not - if back pressure got too high if the internals come's further apart it would just quit running due to lack of exhaust flow .......
Old May 2, 2019 | 03:06 AM
Trip coverage's Avatar
Trip coverage is on a distinguished road
Default Thanks for helping me out
Would the cat breaking up cause the rearend to shake???
Old May 2, 2019 | 04:06 AM
odat's Avatar
Depending on what you mean by shake but A multi hard miss prob would
Old May 3, 2019 | 10:15 AM
Default Thank you for your help.
just got it out of the exhaust shop. No symptom have been repair. With the exception of the rattle and the vibration of the rearend. It is still missing and popping.
One more thing this all started with no warning. It almost seems like someone sabatoged my truck.
Old May 3, 2019 | 11:34 AM
cleburne red's Avatar
OK, so the exhaust shop replaced the cat? And now the rattle and vibration is gone, but it still misses and runs rough?
Old May 3, 2019 | 12:31 PM
Okay, yes the cat has been replaced with a straight pipe.
Took it to AutoZone. It threw 5 codes 2 0300
0171. And 2 0101.
The code reader says the blazer needs a fuel regulator.
Which makes sense because half of air filter is missing. Me and buddy are now tear apart the carb(injectors) to replace this part. Hope this fixes it.
Old May 3, 2019 | 12:35 PM
Did you actually check the fuel pressure, or are you just throwing parts at it? Fuel pressure is super easy to replace, and can determine if the injectors or pump is at fault
Old May 3, 2019 | 12:43 PM
This is what was recommended.
Don't know.
Old May 3, 2019 | 12:44 PM
If it helps we are in a full tooled logging shop.
I work in the logging industry. I have access to a full tooled shop.
Old May 3, 2019 | 12:45 PM
And all the computer readers are locked up. Don't have access to those.
