Rear axle?
Old Jan 7, 2011 | 12:33 PM
Hank's Avatar
Hank is on a distinguished road
Default Rear axle?
Hi there,
How can I see what kind of rear axle I have, whith or whitout limited slip?? ( locking differential)
Is it coded in vin?
Need an oil change, 250 K!! What oil!?
Thanx for helping out!
Old Jan 22, 2011 | 10:48 PM
rbrace's Avatar
rbrace is on a distinguished road
sticker in glove box tells the codes
of rear end gears
Old Jan 23, 2011 | 01:19 AM
TZFBird's Avatar
TZFBird is on a distinguished road
Jack up the rear of the vehicle and put it in neutral. Rotate the driveshaft. If both wheels turn the same direction you have a limited slip. While your at it, make a mark on the driveshaft and a mark on a tire. Turn the wheel one full revolution and count the number of times the driveshaft rotates and a rough estimate at how much it turns in addition. 3 full revilutions and almost 1/4 would be close to a 3.23:1 differential. There are only so many common gear ratios that it could fall close to. Other than that there are some online calculators you can use. If you know the diameter of your wheel and if you run in 3rd gear which is 1:1. You will be able to figure gear ratio based upon RPM vs. MPH(assuming your guages are fairly accurate).
Options if your RPO sticker is missing.
Old Jan 23, 2011 | 01:45 PM
69chevelle's Avatar
69chevelle is on a distinguished road
Originally Posted by Hank
Hi there,
Is it coded in vin?
rpo in glovevox
g80 is locker
ut6 is 3.42
gt4 is 3.73
gt5 is 4.10
going from the top of my head.... coule be off a number on the gt4 and 5
and if your talking rear end oil, Synthetic gear oil.
Old Jan 23, 2011 | 08:11 PM
rbrace's Avatar
i have a 2001 chevy blazer 2dr 5 speed
with a g80 locker and cleaning off rpo sticker
and took the numbers off i think it was a gt5
which is a 410 does this sound right?
Old Jan 23, 2011 | 11:28 PM
69chevelle's Avatar
you are correct.
I myself didn't know they offered the 4.10's in 2001 though. I couldn't find any 98+ with 4.10's when I was looking for axles.
Old Jan 24, 2011 | 05:29 AM
Plug your Vin into the Vin decoder at compnine.com
chowell
Mar 6, 2021 09:47 PM
thrandall
May 3, 2013 04:54 PM
blajeans
Jan 9, 2013 12:58 PM
LucasMI
Jan 2, 2012 02:15 PM
jmaynard
Jul 12, 2011 01:03 PM
