Rear Oil Pan Nuts Size?
Old May 30, 2020 | 11:08 PM
Default Rear Oil Pan Nuts Size?
Hi all,
Can any of you confirm what the size of the nut is that goes on the studs at the rear of the oil pan that are also integral with the rear main seal?
I found this description for item 423 "Nut, hex 5/16-18x.25 286m por (acdelco #12338130)" at https://nemigaparts.com/cat_spares/e...t/00/tx00-046/
I also found this link for the part number: https://www.wholesalegmpartsonline.c.../12338130.html
I'm thinking I'd like to install some additional nylok nuts so to secure the OEM ones in place after I torque them down. I had an oil leak seem to go away after I re-torqued them last summer.
I was surprised to see it listed as non-metric.
Old May 31, 2020 | 07:40 PM
Transman304's Avatar
I can’t say for sure on the size and pitch of the fastener but what size socket was required to tighten? Also not uncommon for gaskets to compress over time just from heating and cooling cycles. Oil pan and valve covers are notorious for this.
Brad
Blazer925
Sep 14, 2012 09:29 PM
Alexquade
Jun 21, 2012 08:59 AM
ZachL90
Jun 23, 2010 09:13 PM
Pokeman
Feb 19, 2008 06:06 AM
black95blazer
Feb 2, 2008 09:04 PM
