RearTransmission output/driveshaft seal
Old Aug 30, 2009 | 01:09 PM
roycet4's Avatar
roycet4 is an unknown quantity at this point
Default RearTransmission output/driveshaft seal
My '97's output shaft/driveshaft seal is leaking. I purchased a new one from Autozone but the one I pruchased is too small. The original one is about 3" OD (flange) and has a rubber boot. I have been looking on line and have not found a match. Any ideas??
The one from Autozone is Timken p/n 9613-S. Unfortuately I am not in a position to pull the old seal and go search around for a new one, I need to R&R the same day.
Thanks in advance for any help
Royce in NH
Old Aug 30, 2009 | 02:00 PM
2wd or 4wd? Auto or Manual?
Old Aug 30, 2009 | 06:15 PM
roycet4's Avatar
Default opps..
4.3 liter 4wd Auto.
I went to VIP auto and the counter guy says the p/n of the Timken seal that I have when I told him what vehicle it was for...Maybe I take the original one off and the smaller one fits in deaper on the transmission tailshaft housing?
Going to try to attach a picture.
Thanks
Royce
Attached Thumbnails RearTransmission output/driveshaft seal-blazer-driveshaft-seal.jpg
Old Aug 30, 2009 | 06:24 PM
That seal will likely work. It will fit into the back of the transfer case, but will not have the dirt/dust boot onto it like the original.
The AC Delco #15661460 will be a direct replacement to what you have currently:
Also, the Timken # 4333N (also available from Autozone) will be a direct replacement as well:
Old Aug 31, 2009 | 05:09 AM
roycet4's Avatar
Smile Perfect
SwartlkkThanks
I will go for either the GM or the Timken seal, too bad these autopart stores do not have this kind of information or if they do, know how to look it up..After this its on to replace the remote oil filter lines (leaking of course..)
Thanks again
Royce
gitch93
Jan 23, 2013 04:51 PM
dudevoit
Mar 8, 2011 06:14 PM
litterbug
Mar 7, 2011 09:14 PM
GLBL WMR
Nov 14, 2009 05:54 PM
jagblazer01
Mar 1, 2006 07:16 PM
