Remote oil cooling lines
Old Jan 11, 2020 | 06:52 AM
Tjborrman's Avatar
Tjborrman is on a distinguished road
Default Remote oil cooling lines
Remote oil cooling lines have a hard time getting to the 13 mm by oil pan
Old Jan 11, 2020 | 07:51 AM
What have you tried?
When I changed them on my old Bravada, I had to jack up a bit on the engine as the engine mounts had sagged a bit over time making things tighter down there. I just used a 2x4 under the oil pan & a floor jack to lift the engine up taking some load off of the engine mounts. That and I used a shallow socket with a wobble extension and enough extensions to get out in front of the axle.
Old Jan 11, 2020 | 01:40 PM
This this is the one that supports the lines with a small bracket? It is a hard one to get to and even harder to start when reinstalling. But it can be done. A ratchet box end wrench my help to get in there.
Old Jan 11, 2020 | 02:41 PM
Strangerock's Avatar
Strangerock is on a distinguished road
unless i'm thinking of a different bolt , I used a foot or more of extensions and went along side the engine from the front.
er0ck273
May 21, 2014 12:50 AM
stiggybaby
May 25, 2012 06:28 PM
Unlimitedsp
Dec 17, 2009 04:15 PM
hhs2006
13
Feb 3, 2008 10:26 PM
