Remote oil filter hose replacement
Old Jan 31, 2025 | 11:14 AM
Originally Posted by AJBert
I meant that I needed to use the extensions, from the front, with a universal and the correct socket with a ratchet. There is no room if going close to the block to move a ratchet. If you can get a cordless or air ratchet in there, you could possibly do the job. The first time I had to change those lines I used extensions, and that is what I have used since. I do have an air ratchet but haven't bothered to try it out. Maybe next time I'll give it a shot. And, yes, there will be a next time, trust me.
It's not a hard job to do, providing you have the right tools. No since in having a shop do it. They will charge much more than what the right tools will cost. Bonus of buying the tools to do the job is you will have them next time the job needs to be done again. Your choice, though.
Totally agree!
When I did mine, I also replaced the o-ring and gasket between the adapter and the block.
I had the o-ring fail on me in a 92 Bkazer when it was about 10 years old.
Old Feb 4, 2025 | 07:17 PM
Stovey's Avatar
Stovey will become famous soon enoughStovey will become famous soon enough
How often do you suppose these lines need to be replaced? I have quite a bad oil leak and wonder if this is the issue.
Do the oil cooler lines also need to be done regularly?
Old Feb 4, 2025 | 10:23 PM
I've only heard people replacing them as needed, and likely once every 10 to 15 years.
If you have a bad leak, it could be due to the o-ring at the adapter to the block going bad.
FrostyyS10
May 6, 2024 09:45 PM
LannyL81
107
Oct 17, 2023 06:01 AM
88BLAZER4X4
May 12, 2014 02:28 PM
maddie's dad
Jun 12, 2012 12:43 AM
naf821
Aug 9, 2007 10:06 PM
