Removed cat and light turned on
Old Jul 17, 2018 | 09:42 PM
Jherr68's Avatar
Jherr68 is on a distinguished road
Default Removed cat and light turned on
So removed catalytic converter and two days later light came on! Sensors up stream no were near cat !? Why did it come on!?
Old Jul 18, 2018 | 03:45 AM
Old Jul 18, 2018 | 08:41 AM
LesMyer's Avatar
The PCM is comparing the cycling of downstream O2 sensor to the cycling of the upstream O2 sensor, and has detected the lack of a working catalytic converter. It's something all vehicles built since 1996 are designed to do and is part of the mandated OBD2 protocol. Also know that the PCM will go into various failsafe modes, depending on the problem presented - so you may defeat any purpose imagined in taking the converter off, if the SES light is now on.
Old Jul 19, 2018 | 12:05 AM
Fixxer's Avatar
Fixxer is on a distinguished road
You could try installing spark plug non-foulers on the downstream O2 sensors, then clear the codes and try again. It worked good for me on a 03 trailblazer with a 5.3. As Lesmyer said, the PCM is looking for the upstream O2 sensors to have big rich/lean swings with a flat constant reading from the downstreams. If you use the non-fouler trick, you move the O2 sensor out of the exhaust stream which makes them look flat. The ECM will then think that the cats are there and functional and your DTC should go away...
TheZR2ThatCould
Apr 17, 2018 10:29 AM
Vahomboy
Jan 1, 2016 05:53 PM
bashultz
14
May 1, 2013 06:08 AM
Flip01002003
Headers, Intake, & Exhaust
Nov 19, 2011 11:22 AM
GMdesigner
Jun 22, 2007 11:43 AM
