removing exhaust help?
Old Nov 2, 2008 | 07:43 PM
brokenfish's Avatar
brokenfish is an unknown quantity at this point
Default removing exhaust help?
I'm not sure if this is the right area, but here goes.
I have a new y pipe, but I can't remove the old one from the manifold. I have used pb's penetrating spray and nothing, it's still stuck. I am trying to keep from removing the manifolds.
It is a 2000 ZR2 blazer.
Old Nov 2, 2008 | 08:07 PM
Default RE: removing exhaust help?
There really is no easy way to do this. You either break them or you dont. Heat helps, but it has to be high, rapidly applied heat, not the propane torch variety. Rapid cooling helps to break the rust bond on the threads too.
Old Nov 2, 2008 | 10:12 PM
Millertime21's Avatar
Millertime21 is an unknown quantity at this point
Yup, no easy way when your working on rusty exhaust. If you don't need to keep your old y-pipe you could probably cut it off. That might give you more room to work on it. I can't remember how hard it is to get to the bolts, but if its hard to get a tool on the bolts, cutting it off as high as you can might help.
Old Nov 3, 2008 | 05:41 AM
mysons95's Avatar
mysons95 is an unknown quantity at this point
Yeah, heat worked for me, even out of a small propane (heehee).
Old Nov 3, 2008 | 07:41 AM
salvy's Avatar
salvy is an unknown quantity at this point
Your best way is bring it to a muffler shop, see if they'll burn off the nuts for you or burn out the studs and replace with new, save yourself a whole lot of aggrevaition at this point, usually an independent shop will do it, for a couple bucks. Because your gonna need an acetylene torch w/oxygen- (cutting torch). Good luck.
Old Nov 4, 2008 | 06:07 PM
brokenfish's Avatar
alright thanks for all the info and I now realised I will have to take off the manifolds.
Old Nov 4, 2008 | 08:18 PM
ravenhurst's Avatar
ravenhurst is an unknown quantity at this point
When I was taking my manifolds out, I found that it was easier to disconnect the pipe with the manifolds still connected to the heads. I also put the blazer on jack stands, and removed the front tires for easier access. A 3/8" drive ratchet and a long extension wasn't enough to break the torque, even after spraying some penetrant to losen it up. Had to use a longer and larger tool for more leverage. They're tight, and luckily mine didn't snap.
phatso_99blaz
Headers, Intake, & Exhaust
Apr 8, 2013 03:16 PM
carterx
May 15, 2009 10:49 AM
wirtner
Dec 28, 2008 08:34 PM
lennyblazer
Oct 21, 2007 07:18 PM
Ucedwhut
14
Aug 9, 2007 01:53 AM
