removing PS pump
Old Dec 11, 2008 | 10:16 PM
ant2297's Avatar
ant2297 is an unknown quantity at this point
Default removing PS pump
how do you remove the pulley to get the three bolts behind it? just looked at it for a second didnt really mess with it at all.
Old Dec 11, 2008 | 10:43 PM
rriddle3's Avatar
Default RE: removing PS pump
There is a power steering pump pulley removal tool made for this. If you do not have a repair manual (Haynes or Chilton) getting one is a good idea.
Old Dec 11, 2008 | 10:53 PM
ant2297's Avatar
so the only way of removing this is by using special tool for it?
Old Dec 11, 2008 | 11:11 PM
rriddle3's Avatar
It's the only way I know, but others might have another way.
Old Dec 12, 2008 | 11:10 AM
The special tool is the only way that I would recommend someone remove the pulley. There are other ways, but all of them will result in damage to the pulley. Some autoparts stores rent out this puller at no cost (aside from a deposit which you get back in full when you return the tool).
Old Dec 12, 2008 | 11:22 AM
ant2297's Avatar
okay thank you. ill go to my auto parts store today and see what i can do.
Old Dec 12, 2008 | 12:12 PM
samuknow's Avatar
samuknow is an unknown quantity at this point
ORIGINAL: swartlkk
that is the way to go. It may cost 30 bucks up front but you get it back.
Old Dec 12, 2008 | 04:24 PM
ant2297's Avatar
yea i got it today for 34 bucks. now the only thing thats keeping me from getting to the pulley is the fan. how do i remove that? Im trying to remove the lower intake manifold to replace the gasket. The only thing thats keeping me from removing it is the lower right corner bolt and a hose behind that. the power steering pump bracket for the ac, you know that whole unit is getting in my way. so far i removed the distributor, the upper intake manifold, cap, rotor, plugs, coil, sensors, most the bolts around the intake manifolds, and everything else im sure im supposed to be taking off. if you guys think im doing anything wrong let me know. i got the alldata intructions on it but i havent read them in a while. i never really worked on my truck and now it seems like chevys are a pain in the ***.
Old Dec 12, 2008 | 04:53 PM
samuknow's Avatar
You need a big crescent wrench and a screwdriver. Use the screwdriver to pry between the small bolts to stop it from spinning when turning the big nut behind the fan.
[IMG]local://upfiles/12798/BC70AFFABCC040719C4BB6FB1C948D6C.jpg[/IMG]
Old Dec 12, 2008 | 05:31 PM
I have done it like that before. My favorite method is to just leave the belt on. Then put a big crescent wrench on it and smack it with a hammer.
If the belt does not provide enough resistance, and you have some extra hands at your disposal, then put a breaker bar on the tension pulley and instead of loosening it, tighten it. Works like a charm!
