removing PS pump
Old Dec 12, 2008 | 06:27 PM
ant2297's Avatar
ant2297 is an unknown quantity at this point
Default RE: removing PS pump
thanks guys maybe i can get something done tonight.
Old Dec 12, 2008 | 07:21 PM
fondo's Avatar
fondo has a little shameless behavior in the past
The ps pump pulley is gonna be on there pretty tight and it won't just pop off once you get to certain amount of pressure on the puller bolt. It is a slow process but should come off with the right puller. On the fan clutch, they make special wrenches that are designed just for that large nut along with a holding tool. But whatever you can use to improvise I'm sure will do.
Old Dec 14, 2008 | 12:18 PM
ant2297's Avatar
ok so far i got the fan removed but the tool to remove the ps pump pulley is actually too big. the main threaded screw which does the pushing, not the arms of the tool, is actually too long and i cant fit it in between the rad and pulley. what should i do now? do they sell shorter ones or do i have to remove the rad? and if i do have the remove the radiator will i lose tranny fluid when i disconnect the lines from the transmission?
BouncingRadical
14
Nov 27, 2015 12:30 AM
bruuce
28
Oct 23, 2011 09:31 PM
cide
Nov 7, 2009 01:26 PM
junkmonkey
Mar 29, 2007 08:01 PM
mytruck2
Dec 13, 2006 04:50 PM
