Replace Spider injectors??
Old Feb 8, 2018 | 05:03 PM
jeffzzr250's Avatar
jeffzzr250 is on a distinguished road
Default Replace Spider injectors??
I have to replace the intake manafold gasket 160,000 miles Would it be worth it as preventive maintenance to replace the spider injectors while the intake manifold off. The only reason would be saving time and labor down the road to pull it again. Or is a visual inspinspection of the injectors good enenou.
Old Feb 8, 2018 | 05:12 PM
newguy's Avatar
I would say thats your choice, myself, yes i would
Old Feb 8, 2018 | 06:55 PM
I was in yoru same situation at 130k miles with my 1999. I went ahead and replaced mine with the upgraded model. The upgraded injectors are only appropriate for maybe 98+.
Old Feb 8, 2018 | 07:10 PM
jeffzzr250's Avatar
Did you notice an improvement with gas mileage?
Old Feb 8, 2018 | 07:23 PM
Can't say I did but I also have a failing O2 sensor that I think is mucking up the computer calculations. Also, it has not been in a whole year yet and my driving habits in the winter and fall are very different than the spring and summer. Also the gas blend might be different.
My figuring was that after almost 20 years, replacing the spider was more of a one-time preventative maintenance that might also give me better mileage.
Old Feb 8, 2018 | 07:30 PM
Santa's 93Blazzz's Avatar
Santa's 93Blazzz is on a distinguished road
I would for sure if you planned on keeping it, would also do the plumbing lines into the intake to the spider.. again only if your going to keep it.
dman001948
Oct 29, 2014 09:25 PM
Dadatone
Nov 13, 2012 08:18 PM
fire_nut
Dec 12, 2011 05:37 PM
Opi
Aug 13, 2011 12:06 AM
lowbucktruck
Sep 17, 2007 05:20 AM
