Replaced B1S1 O2 Still get same codes
Old Jan 15, 2009 | 04:34 PM
1blkblazer422's Avatar
1blkblazer422 is an unknown quantity at this point
Default Replaced B1S1 O2 Still get same codes
I have a 1998 Blazer and had two codes in the PCM a P0135 abd P0146. I was searching the forum and read how common the 146 code was so I was gonna deal with that code later. The other code was B1S1 Heater performance so I replaced the sensor with a AC delco sensor. Cleared the codes and drove to work and back and both codes returned. The post cat 02 wouldnt mess with the b1s1 02 would it? I dont know why both codes returned?
Old Jan 15, 2009 | 08:38 PM
Default RE: Replaced B1S1 O2 Still get same codes
The presence of an O2 sensor code, especially a heater code, does not automatically mean that the O2 sensor is bad. It could be a ground or other wiring problem. The P0135 Explained thread will walk you through the diagnostic procedure.
Old Jan 17, 2009 | 10:39 PM
Thanks for the help I will troubleshoot through the charts.
mikepro
Aug 15, 2011 07:03 PM
AmberRose
Aug 30, 2010 08:58 PM
steelcityneal
Jan 10, 2010 09:23 PM
yazan84
Dec 29, 2007 11:38 PM
MeidleinA
Jan 17, 2006 01:31 AM
