hub bearing replaced... still hear hearing the same noise!
Old Dec 29, 2007 | 01:31 AM
yazan84's Avatar
yazan84 is an unknown quantity at this point
Default hub bearing replaced... still hear hearing the same noise!
So I've changed my front right side bearing hub, however I'm still hearing the same noise and the tire still shakes and moves like it's not held tight. The mechanic told me that I need lower ball joints. Now I've replaced on upper ball joint on the right side because it was damaged and it was terrible. It bent my shield and cut off my ABS links. Don't want to go off topic too much...
but anybody have any other ideas?
Old Dec 29, 2007 | 03:03 AM
Chevy Lover's Avatar
Default RE: hub bearing replaced... still hear hearing the same noise!
Can you describe when you hear the noise ( left or right turns, bumps, speed etc..) and can you describe the noise?
Old Dec 29, 2007 | 10:58 AM
yazan84's Avatar
ummm sounds like air waves lol dunno huuub huuub huuub huuub huuub huub... sounds like it's under the driver side
Old Dec 29, 2007 | 12:21 PM
ORIGINAL: Chevy Lover
Can you describe when you hear the noise ( left or right turns, bumps, speed etc..) ?
Ok, you've answered part of the question. I'm trying to figure out if you need to change the left side hub bearing.
Old Dec 29, 2007 | 11:38 PM
yazan84's Avatar
actually I noticed today at speed over 35 when I ever move the steering wheel to the left the noise gets worse.... not as bad to the right but it makes slight noise though.
dixie1864
Nov 20, 2010 12:36 PM
AmberRose
Aug 30, 2010 08:58 PM
GMJimmy
Apr 18, 2010 04:58 PM
BonestockZR2
Dec 15, 2009 05:31 AM
1blkblazer422
Jan 17, 2009 10:39 PM
