Replacing engine flywheel/flexplate
Old Apr 22, 2008 | 02:54 PM
jonesjamesw's Avatar
jonesjamesw is an unknown quantity at this point
Default Replacing engine flywheel/flexplate
Can anyone tell what a reasonable timeline would be for a trained/certified mechanic to charge for in labor for replacing an engine flywheel/flexplate in a 1997 blazer would be?
Thanks
JJ
Old Apr 22, 2008 | 04:47 PM
blazinrebel's Avatar
blazinrebel is an unknown quantity at this point
Default RE: Replacing engine flywheel/flexplate
is the truck manual or automatic
Old Apr 22, 2008 | 08:54 PM
Hanr3's Avatar
8 hrs.
It will take 4 hours to remove the tranny and 4 hours to reinstall it. You can do it yourself if you have some mechanical experience. Searcht eh Do-It-yourself section for my thread on tranny removal. In this case there are a few things you can not do, however the tranny basically has to come out of the truck, or rahter slide back 4" or so you can get tools on the flexplate (automatic) and remove it. I use longer bolts to replace the tranny bolts and slide it back on the longer bolts. Howver you still have to remove the driveshafts, t-case, exhaust cross over pipe, torque converter, and unbolt the tranny from teh engine. Plus the wires and hoses attached.
Old Apr 23, 2008 | 02:37 PM
automatic
Old Apr 28, 2008 | 02:03 PM
tankie88's Avatar
tankie88 is an unknown quantity at this point
I did my 85 M1009 blazer in 4.5 hours.Trans and transfer box as one unit,moved it back about 6 ins.
Old Apr 28, 2008 | 09:55 PM
Hanr3's Avatar
that would be a bout right for a fullsize. you got a ton more space to play with then the S10 versions.
Kirk-NJ
Feb 17, 2010 05:31 PM
Brians650
Jan 10, 2010 11:50 AM
Taurus24/7
Dec 29, 2008 09:25 AM
offskooring
Dec 19, 2008 03:22 PM
azradrods99
Jan 20, 2007 02:08 AM
